path: root/configs/nanopi_m1_plus_defconfig
2019-04-10arm: sunxi: Enable DRAM ODT by default on H3/H5Paul Kocialkowski
Most of the boards we support with H3/H5 enable DRAM on-die termination, which is consistent with the high DRAM clocks that are used. Make it the default (like it's done for other similar platforms) instead of defining it in each defconfig. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-04-10arm: sunxi: Set the default DRAM ZQ value to 3881979 on H3/H5Paul Kocialkowski
Most H3/H5 boards we support have the DRAM ZQ value set to 3881979, which is also consistent with the default set for the R40. Make this value the default on H3/H5 instead of 123. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-18sunxi: usb: Switch to Generic host controllersJagan Teki
Onc of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch sunxi USB use EHCI and OHCI Generic controllers. Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD where it already have USB_EHCI_HCD Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-08sun8i: h3: Add initial NanoPi M1 Plus supportJagan Teki
NanoPi M1 Plus is designed and developed by FriendlyElec for professionals, enterprise users, makers and hobbyists using the Allwinner H3 SOC. NanoPi M1 Plus key features - Allwinner H3, Quad-core Cortex-A7@1.2GHz - 1GB DDR3 RAM - 8GB eMMC - microSD slot - 10/100/1000M Ethernet - Serial Debug Port - 5V 2A DC power-supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
