path: root/configs/nanopi_m1_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-30sunxi: Add support for NanoPi M1Mylene JOSSERAND
NanoPi M1 is a board based on Allwinner H3 CPU. This commit adds the support for this platform with: - an include device tree which enables UART, LEDs, GPIO key switch, 1 USB host ports and the SD-card as a dtsi file. - a device tree specific to this board that enables the 2 additional USB ports - a defconfig file for minimal support - a section in MAINTAINERS (add myself) Synchronized with the kernel device tree, from commits: sun8i-nanopi.dtsi: 85d2913614d9ab899d23b7ab7d22d23cf45bd1de sun8i-h3-nanopi-m1.dts: 10efbf5f16336b7540ad6a16aa1cb0b26bab033b Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
