cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
NanoPi A64 is a new board of high performance with low cost
designed by FriendlyElec., using the Allwinner A64 SOC.
Nanopi A64 features
- Allwinner A64, 64-bit Quad-core Cortex-A53@648MHz to 1.152GHz, DVFS
- 1GB DDR3 RAM
- MicroSD
- Gigabit Ethernet (RTL8211E)
- Wi-Fi 802.11b/g/n
- IR receiver
- Audio In/Out
- Video In/Out
- Serial Debug Port
- microUSB 5V 2A DC power-supply
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
