path: root/configs/nanopi-neo4-rk3399_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-02rockchip: Enable HDMI output on rk3399 board w/ HDMIJagan Teki
Enable config options and console setting to respective rk3399 board for HDMI output. Boards supported and tested on this patch are: - NanoPc T4 - NanoPi M4 - NanoPi Neo4 - ROC-RK3399-PC - Rock960 Cc: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-02-20rockchip: rk3399: add target type for evb based boardKever Yang
There are many boards share the board file and device header file with rk3399 evb, add target type MACRO so that it is fixed instead of default to the first target in "RK3399 board select". Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30rockchip: rk3399: Enable DISPLAY_CPUINFOJagan Teki
RK3288, RK3399 are now support cpu-info, so enable DISPLAY_CPUINFO by default. Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-11-11Merge tag 'u-boot-rockchip-20191110' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Add support for rockchip pmic rk805,rk809, rk816, rk817 - Add rk3399 board Leez support - Fix bug in rk3328 ram driver - Adapt SPL to support ATF bl31 with entry at 0x40000 - Fix the u8 type comparision with '-1'. - Fix checkpatch warning for multi blank line and review signature.
2019-11-10rockchip: rk3399: update SPL_STACK_R_ADDRKever Yang
Use the same SPL_STACK_R_ADDR in Kconfig instead of each board config; default to 0x4000000(64MB) instead of 0x80000(512KB) for this address can support all the SoCs including those may have only 64MB memory, and also reserve enough space for atf, kernel(in falcon mode) loading. After the ATF entry move to 0x40000, the stack from 0x80000 may be override when loading ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-10rockchip: rk3399: defconfig: no need to reserve IRAM for SPLKever Yang
We use to reserve IRAM to avoid the SPL text overlap with ATF M0 code, and when we introduce the TPL, the SPL space is in DRAM, we reserve space to avoid SPL text overlap with ATF bl31. Now we decide to move ATF entry point to 0x40000 instead of 0x1000, so that the SPL can have 0x4000 as code size and no need to reserve space or relocate before loading ATF. The mainline ATF has update since: 0aad563c rockchip: Update BL31_BASE to 0x40000 Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-23rockchip: rk3399: defconfig: remove SPL raw image supportKever Yang
RK3399 SPL only support FIT image for ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-20rockchip: rk3399: default enable SPL LIBCOMMON and LIBGENERICKever Yang
We needs SPL LIBCOMMON and LIBGENERIC for all boards, so we can enable them by default and no need to define in each board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-20rockchip: rk3399: use default value for SYS_MALLOC_F_LENKever Yang
There is no difference in rk3399 board use for SYS_MALLOC_F_LEN, so we can use default value. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-21configs: Resync with savedefconfigTom Rini
2019-05-30rockchip: rk3399: Add Nanopi NEO4 board supportJagan Teki
Add initial support for Nanopi NEO4 board. Specification - Rockchip RK3399 - 1GB DDR3-1866 - SD card slot - eMMC Socket - RTL8211E 1Gbps - AP6212 WiFI/BT - HDMI In/Out, DP, MIPI CSI - USB 3.0, 2.0 - USB Type C power and data - GPIO expansion ports - DC 5V/3A Commit details of rk3399-nanopi-neo4.dts sync from Linux: "arm64: dts: rockchip: Add Nanopi NEO4 initial support" (sha1: 092470b537f19788d957aed12d835a179b606014) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
