path: root/configs/nanopi-k2_defconfig
2021-08-31Convert CONFIG_SYS_LOAD_ADDR to KconfigTom Rini
Now that we have consistent usage, migrate this symbol to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-06-28configs: Resync with savedefconfigTom Rini
2021-05-11configs: Resync with savedefconfigTom Rini
2021-04-06configs: meson: use Designware glue driver for Amlogic Meson8b & later SoCsNeil Armstrong
Use the proper Synopsys DWMAC Meson8b glue to handle the ethernet link type. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-10-09configs: Resync with savedefconfigTom Rini
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-04configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-04-23board: amlogic: enable PHY_REALTEK for selected boardsNeil Armstrong
When using the generic PHY on boards using an RGMII Realtek PHY, gigabit speed is not always reliable. This patch enables the Realtek PHY driver for such boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: meson: display Amlogic SoC InformationJulien Masson
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family. This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing. Signed-off-by: Julien Masson <jmasson@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: also updated new p200/p201 defconfigs]
2018-11-26ARM: rework amlogic configurationJerome Brunet
Rework the board SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME setup by moving the board Kconfig into the mach-meson Kconfig to make it easier to add new boards for a SoC architecture and add a custom config header or custom board handler for a platform. This drops the board CONFIGs and the duplicate boards configs headers in favor of a single meson64.h config header. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: factorise gxbb boardsJerome Brunet
The nanopi-k2 and the odroid-c2 are similar enough to be supported by the same u-boot board. This change use odroid-c2 u-boot board for the nanopi-k2 as well. Dedicated defconfig are kept to customize the names and device tree. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-19boards: amlogic: Add FriendlyElec NanoPi K2 board supportThomas McKahan
This adds platform code for the FriendlyElec NanoPi K2 board based on a Meson GXBB (S905) SoC with the Meson GXBB configuration. This initial submission only supports: - UART - MMC/SDCard - Ethernet - Reset Controller - Clock controller Cc: Yuefei Tan <yftan@friendlyarm.com> Signed-off-by: Thomas McKahan <tonymckahan@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
