VID 0x525 and PID 0xa4a5 already registered as
PLX Technology, Inc.
Linux-USB File-backed Storage Gadget
But fastboot device is not mass storage devices
windowns 10 latest update already cached above vid/pid
Change to use Freescale VID 0x1fc9
PID 0x151, for SPL SDP HID download
PID 0x152, for Fastboot
PID 0x153, for Kernel fastboot
Need update uuu above 1.4.182
Signed-off-by: Frank Li <Frank.Li@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 7b84c587ba607844d53a7553c7238e6acd0bba9a)
https://source.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20211020
First PR from u-boot-imx for 2022.01
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/9535
- new board: kontron-sl-mx8mm
- imx8m:
- fix secure boot
- imx ESDHC: fixes
- i.MX53: Support thum2, bmode and fixes for Menlo board
usbarmory switch to Ethernet driver model
- imx6 :
- DDR calibration for Toradex boards
- imx7:
- Fixes
- Updated gateworks boards (ventana / venice)
# gpg verification failed.
Move setting CONFIG_BOOTCOMMAND to the mx7ulp_com_defconfig file.
It also allows replacing the default CONFIG_BOOTCOMMAND without
code modification.
Signed-off-by: Ricardo Salveti <ricardo@foundries.io>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Resync all defconfig files using moveconfig.py
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- Provide a default Kconfig value of the default script
- Largely continue to define this via the board Kconfig file
- For the boards that select a script based on defconfig rather than
TARGET, keep this within the defconfig.
Now that we have consistent usage, migrate this symbol to Kconfig.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
The Embedded Artists COM board is based on NXP i.MX7ULP.
It has a BD70528 PMIC from Rohm with discrete DCDC powering option and
improved current observability (compared to the existing NXP i.MX7ULP EVK).
Add the initial support for the board.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
