path: root/configs/mx7dsabresd_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-03-10mx7dsabresd: Boot in non secure by defaultFabio Estevam
Booting a mainline kernel in secure mode on i.MX7D causes only one CPU to be brought up. Change it to booting in non secure mode by default, which allows the two CPUs to be brought up. It does have a side effect of not probing the CAAM driver. If CAAM driver is needed then a secure world OS such as OPTEE needs to be used. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-07mx7dsabre: Remove warning about DM_SPI_FLASHJoris Offouga
This defconfig doesn't need it. Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2020-01-07mx7dsabre: Convert to distroboot supportJoris Offouga
2020-01-07mx7dsabre: Enable DM_ETHJoris Offouga
Also sync device tree with v5.5-rc1 Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-10-04Kconfig: Migrate CONFIG_BOOTM_* optionsTom Rini
Migrate all of the existing OS support options that are under CONFIG_BOOTM_* to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-08-07configs: Resync with savedefconfigTom Rini
2018-04-30Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-26mx7dsabresd: Remove the mx7dsabresd_secure_defconfig targetFabio Estevam
mx7dsabresd_secure_defconfig was introduced to allow booting NXP kernel that has CAAM support and needs to boot in secure mode. Instead of keeping two different config targets for the same board, remove mx7dsabresd_secure_defconfig and select CONFIG_ARMV7_BOOT_SEC_DEFAULT inside mx7dsabresd_defconfig so that this target could be used to boot both mainline and the vendor kernel. This makes maintenance task easier and avoid potentially confusion for the end user. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
2018-02-04imx: mx7dsabresd: enable UHS and HS200Peng Fan
Enable UHS and HS200 for mx7dsabresd. Read Speed improvement: Kingston SD10VG2/16GB SDHC 3.0 card 22.2MB/s -> 73.7MB/s eMMC5.0 MTFC8GACAEAM: 68MB/s -> 87MB/s Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-31Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-18imx: mx7dsabresd: switch to DM USBPeng Fan
Switch to use DM USB. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2017-05-18imx: mx7dsabresd: enable more DM driversPeng Fan
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled. So needs to enable them together. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-05-18arm: dts: imx7d-sdb add basic dtsPeng Fan
Add basic dts for i.MX7D-SDB board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-07-19mx7_common: use Kconfig for ARMv7 non-secure modeStefan Agner
Use existing Kconfig symbols to let the user configure whether to build a U-Boot with non-secure mode support or not. This also allows to enable virtualization extension easily. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
