path: root/configs/mx7dsabresd_defconfig
2018-02-04imx: mx7dsabresd: enable UHS and HS200Peng Fan
Enable UHS and HS200 for mx7dsabresd. Read Speed improvement: Kingston SD10VG2/16GB SDHC 3.0 card 22.2MB/s -> 73.7MB/s eMMC5.0 MTFC8GACAEAM: 68MB/s -> 87MB/s Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-31Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-18imx: mx7dsabresd: switch to DM USBPeng Fan
Switch to use DM USB. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2017-05-18imx: mx7dsabresd: enable more DM driversPeng Fan
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled. So needs to enable them together. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-05-18arm: dts: imx7d-sdb add basic dtsPeng Fan
Add basic dts for i.MX7D-SDB board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-07-19mx7_common: use Kconfig for ARMv7 non-secure modeStefan Agner
Use existing Kconfig symbols to let the user configure whether to build a U-Boot with non-secure mode support or not. This also allows to enable virtualization extension easily. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-19usb: ehci-mx6: introduce config for high active power pinStefan Agner
Add a new config CONFIG_MXC_USB_OTG_HACTIVE which configures the OTG Power Pin to be high active. Low active is the reset value of the affected configuration register, hence the config option is named by the non-reset configuration. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-19usb: move CONFIG_USB_EHCI_MX7 to KconfigStefan Agner
Create an entry for "config USB_EHCI_MX7" in Kconfig and switch over to it for all boards. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-03-26imx: mx7d: move MX7D to Kconfig entryPeng Fan
If including MX7D in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS will not effect.So move MX7D to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to "select MX7D" to boards using i.MX7 Dual. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-21imx: mx7d: isolate resources to domain 0 for A7 corePeng Fan
In current design, if any peripheral was assigned to both A7 and M4, it will receive ipg_stop or ipg_wait when any of the 2 platforms enter low power mode. We will have a risk that, if A7 enter wait, M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait asserted same time. Also if M4 enters stop mode, A7 will have no chance to access the peripheral. There are 26 peripherals affected by this IC issue: SIM2(sim2/emvsim2) SIM1(sim1/emvsim1) UART1/UART2/UART3/UART4/UART5/UART6/UART7 SAI1/SAI2/SAI3 WDOG1/WDOG2/WDOG3/WDOG4 GPT1/GPT2/GPT3/GPT4 PWM1/PWM2/PWM3/PWM4 ENET1/ENET2 Software Workaround: The solution is to set the peripherals to Domain0 by A core, since A core in Domain0. The peripherals which will be used by M4, will be set to Domain1 by M4. For example, A core set WDOG4 to domain0, but when M4 boots up, M4 will set WDOG4 to domain1, because M4 will use WDOG4. So the peripherals are not shared by them. This way requires the uboot implemented the RDC driver and set the 26 IPs above to domain 0 only. M4 image will set the M4 to domain 1 and set peripheral which it will use to domain 1. This patch enables the CONFIG_IMX_RDC and CONFIG_IMX_BOOTAUX for i.MX7D SABRESD board, and setup the 26 IP resources to domain 0. Signed-off-by: Ye.Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2015-09-13imx: mx7dsabresd: Add support for MX7D SABRESD boardAdrian Alonso
* Add i.MX7D SABRESD target board support with enabled modules: UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX. Build target: mx7dsabresd_config Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Adrian Alonso <aalonso@freescale.com>
