Since the mx6ulz don't have FEC, it needs to use USB2NET dongle
to connect network. We decouple the CONFIG_FEC_MXC with CONFIG_CMD_NET.
For 6ull, all defconfigs need to enable the CONFIG_FEC_MXC explicitly.
Another change is adding ${usb_net_cmd} environment for usb start command
in netboot scripts on 6ulz.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Modify mx6ullevk.h file and deconfig files to enable fastboot in
mx6ull_14x14 and mx6ull_9x9 board
Signed-off-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Add new build configs for 9x9 evk and NAND/QSPI boot.
Update 14x14 EVK build config to align with v2017.03
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
To support QSPI DM driver
- Add spi0 alias for qspi node. Which is used for bus number 0.
- Modify the n25q256a@0 compatible property to "spi-flash".
- Modify spi4 (gpio_spi) node to spi5
- Define DM SPI/QSPI related config to enable QSPI
Signed-off-by: Peng Fan <peng.fan@nxp.com>
In order to provide a consistent user experience for imx board users,
remove the custom CONFIG_BOOTDELAY values from defconfig files, so that
all boards can use the default two second delay.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the
SD/eMMC card cannot be used.
Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure.
Tested on mx6slevk, mx7dsabresd and mx6ullevk.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Adam Ford <aford173@gmail.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Tested-by: Jagan Teki <jagan@openedev.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Now that the driver supports it, move these boards over to use driver
model fully for MMC.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Generated by "tools/moveconfig -s".
This will make config moves easier.
Add defconfig file to use plugin code.
