Update mx6ull evk to add features from v2016.03.
1. Add support for NAND flash.
2. Add support for QSPI DM driver.
3. Add USB DM driver support.
4. Add two FEC support by using DM FEC driver
5. Update environments for various boot devices support: SD/NAND/eMMC/QSPI
6. Add MFGtool environments.
7. Add board codes for 9x9 EVK board
For the DTS file, some changes are needed for using QSPI DM driver
1. Add spi0 alias for qspi node. Which is used for bus number 0.
2. Modify the n25q256a@0 compatible property to "spi-flash".
3. Modify spi4 (gpio_spi) node to spi5
Signed-off-by: Ye Li <ye.li@nxp.com>
Add LCD configurations and TFT43AB display settings for mx6sllevk.
Enable the CONFIG_VIDEO for this feature.
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Generated by "tools/moveconfig -s".
This will make config moves easier.
Add defconfig file to use plugin code.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
