Signed-off-by: Jagan Teki <jagan@openedev.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs
into respective used defconfigs.
- CONFIG_FSL_QSPI
- CONFIG_SPI_FLASH
- CONFIG_SPI_FLASH_BAR
- CONFIG_SPI_FLASH_STMICRO
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
Discard MX6UL from CONFIG_SYS_EXTRA_OPTIONS, since we default
select MX6UL for mx6ul_14x14_evk board.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Add enet support for mx6ul_14x14_evk board:
1. add pinmux settings
2. implement board_eth_init
3. implement board_phy_config
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig.
Add enable "CONFIG_ARCH_MX6" for boards based on mx6.
Then we can choose target boards using "make ARCH=arm menuconfig"
with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when
"make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig,
kconfig will complains "arch/../configs/platinum_titanium_defconfig:3:
warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Eric BĂ©nard <eric@eukrea.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Soeren Moch <smoch@web.de>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Soeren Moch <smoch@web.de>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support.
2. Support SPL
3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default
supports sd for usdhc2, but can do hardware rework to make usdhc2 support
emmc.
Boot Log:
U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0
- invalid sensor device
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
