path: root/configs/mx6ul_14x14_evk_defconfig
2015-09-02imx: mx6ul_14x14_evk discard MX6UL from CONFIG_SYS_EXTRA_OPTIONSPeng Fan
Discard MX6UL from CONFIG_SYS_EXTRA_OPTIONS, since we default select MX6UL for mx6ul_14x14_evk board. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-02imx: mx6ul_14x14_evk add ENET supportPeng Fan
Add enet support for mx6ul_14x14_evk board: 1. add pinmux settings 2. implement board_eth_init 3. implement board_phy_config Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-02imx: mx6ul_14x14_evk add basic board supportPeng Fan
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support. 2. Support SPL 3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default supports sd for usdhc2, but can do hardware rework to make usdhc2 support emmc. Boot Log: U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59) reading u-boot.img reading u-boot.img U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800) CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0 - invalid sensor device Reset cause: POR Board: MX6UL 14x14 EVK I2C: ready DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
