Remove CONFIG_BCB_SUPPORT config from BSP u-boot defconfig files.
So that we can eliminate such errors during boot up:
can't find partition: misc, dump the partition table
idx 0, ptn 0 name='gpt' start=0 len=2048
idx 1, ptn 0 name='tos' start=0 len=2047
idx 2, ptn 0 name='all' start=0 len=7864320
idx 3, ptn 0 name='bootloader' start=2 len=4094
idx 4, ptn 1 name='mmcsdb1' start=20480 len=1024000
idx 5, ptn 2 name='mmcsdb2' start=1228800 len=6635520
cannot get the partion info for misc
Cannot find partition 4080
do_raw_read failed, ret 1
read_bootctl, bcb_rw_block read failed
read command failed
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 4d282a7a429876f1c1c67754a1d5c7aaaf75bb43)
i.MX6SoloX boards enable fastboot as default.
Support: mx6sxsabresd_defconfig
mx6sxsabresd_emmc_defconfig
mx6sxsabresd_optee_defconfig
mx6sxsabresd_plugin_defconfig
uuu will use fastboot command to write emmc.
Except: mx6sxsabresd_m4fastup_defconfig
mx6sxsabresd_qspi2_defconfig
mx6sxsabresd_spl_defconfig -- this one will fail without any
changes when execute 'make -j8'.
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
Update mx6sxsabresd defconfig to align with v2017.03 with DM SPI and
DM ethernet enabled.
Add other configs to support QSPI2 boot, reworked eMMC, M4 fastboot and
plugin.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Enable I2C/MMC/GPIO/REGUALTOR/PMIC/USB DM drivers.
There are some dependency, such as when DM MMC enabled, USB compile error.
Also the i.MX I2C MMC DM driver does not support legacy GPIO interface.
So enable them all together.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable DTS and OF_CONTROL for i.MX6SX-SDB.
Currently only imx6sx-sdb.dtb is loaded, but if revA board is used the
correct dtb is imx6sx-sdb-reva.dtb, so make this possible.
While at it, remove an extra 'mmc dev'.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
In order to provide a consistent user experience for imx board users,
remove the custom CONFIG_BOOTDELAY values from defconfig files, so that
all boards can use the default two second delay.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
mx6sxsabresd can run different kernel versions, such as NXP 4.1 or mainline.
Currently the rootfs location is passed via mmcblk number and the
problem with this approach is that the mmcblk number for the SD
card changes depending on the kernel version.
In order to avoid such issue, use the UUID method to specify the
rootfs location.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS
will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to
"select MX6SX" to boards using i.MX6 SoloX.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig.
Add enable "CONFIG_ARCH_MX6" for boards based on mx6.
Then we can choose target boards using "make ARCH=arm menuconfig"
with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when
"make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig,
kconfig will complains "arch/../configs/platinum_titanium_defconfig:3:
warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Eric BĂ©nard <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Soeren Moch <smoch@web.de>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Soeren Moch <smoch@web.de>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This commit moves:
- CONFIG_SPI_FLASH_BAR
from include/configs/*.h into configs/*_defconfigs
Signed-off-by: Jagan Teki <jteki@openedev.com>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This option has a bool type, not hex.
Fix it and enable it if CONFIG_DM is on because Driver Model always
requires malloc memory. Devices are scanned twice, before/after
relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc
memory before relocation. As it is board-independent, handle it
globally.
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig
as 0x400. Each defconfig or Kconfig need not repeat the same value.
Use Kconfig instead of board config for DM and DM_THERMAL.
Move this option to Kconfig and update all boards.
mx6sxsabresd was not in the master branch when the conversion to the new Kconfig
style happened, so convert it now so that it can build again.
