add fastboot for qspi u-boot
Signed-off-by: Han Xu <han.xu@nxp.com>
The u-boot changed to check CONFIG_IS_ENABLED for SYS_CONSOLE_IS_IN_ENV,
so we have to set the configuration in defconfig not in header file,
otherwise the checking will fail and lead to use vga for stdout and stderr
when video is enabled.
Fix the issue by moving CONFIG_VIDEO and CONFIG_SYS_CONSOLE_IS_IN_ENV to
defconfig and remove duplicated configurations from header file.
Signed-off-by: Ye Li <ye.li@nxp.com>
Update mx6sxsabreauto defconfig to align with v2017.03.
Add other configs to support QSPI1 boot, NAND boot and plugin.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This converts CONFIG_NAND_MXS to Kconfig.
In order to provide a consistent user experience for imx board users,
remove the custom CONFIG_BOOTDELAY values from defconfig files, so that
all boards can use the default two second delay.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the
SD/eMMC card cannot be used.
Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure.
Tested on mx6slevk, mx7dsabresd and mx6ullevk.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Adam Ford <aford173@gmail.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Tested-by: Jagan Teki <jagan@openedev.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Now that the driver supports it, move these boards over to use driver
model fully for MMC.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers
for mx6sxsabreauto board. Drop non-DM code.
Note:
The i.MX DM drivers has such dependency.
MXC GPIO -> MXC I2C -> PFUZE/REGULATOR
MXC GPIO -> PCA953X
MXC GPIO -> FSL_USDHC
So the drivers needs to be enabled all to avoid
compiling error.
The uboot dm tree log:
=> dm tree
Class Probed Name
root [ + ] root_driver
thermal [ ] |-- imx_thermal
simple_bus [ + ] |-- soc
simple_bus [ + ] | |-- aips-bus@02000000
simple_bus [ ] | | |-- spba-bus@02000000
gpio [ + ] | | |-- gpio@0209c000
gpio [ + ] | | |-- gpio@020a0000
gpio [ + ] | | |-- gpio@020a4000
gpio [ + ] | | |-- gpio@020a8000
gpio [ + ] | | |-- gpio@020ac000
gpio [ + ] | | |-- gpio@020b0000
gpio [ + ] | | |-- gpio@020b4000
simple_bus [ ] | | |-- anatop@020c8000
simple_bus [ ] | | |-- snvs@020cc000
pinctrl [ + ] | | `-- iomuxc@020e0000
pinconfig [ + ] | | `-- imx6x-sabreauto
pinconfig [ + ] | | |-- i2c2grp-1
pinconfig [ + ] | | |-- i2c3grp-2
pinconfig [ ] | | |-- uart1grp
pinconfig [ + ] | | |-- usdhc3grp
pinconfig [ ] | | |-- usdhc3grp-100mhz
pinconfig [ ] | | |-- usdhc3grp-200mhz
pinconfig [ + ] | | |-- usdhc4grp
pinconfig [ + ] | | `-- vccsd3grp
simple_bus [ + ] | |-- aips-bus@02100000
mmc [ + ] | | |-- usdhc@02198000
mmc [ + ] | | |-- usdhc@0219c000
i2c [ + ] | | |-- i2c@021a4000
i2c_generic [ + ] | | | |-- generic_8
i2c_generic [ + ] | | | `-- generic_4e
i2c [ + ] | | `-- i2c@021a8000
gpio [ + ] | | |-- gpio@30
gpio [ + ] | | `-- gpio@32
simple_bus [ ] | `-- aips-bus@02200000
simple_bus [ ] | `-- spba-bus@02200000
simple_bus [ + ] `-- regulators
regulator [ + ] `-- regulator@0
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Enable pinctrl driver for mx6sxsabreauto board.
Add dts for mx6sxsabreauto board.
dts related files imported fro Linux (commit e5517c2a5a4).
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs
into respective used defconfigs.
- CONFIG_FSL_QSPI
- CONFIG_SPI_FLASH
- CONFIG_SPI_FLASH_BAR
- CONFIG_SPI_FLASH_STMICRO
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS
will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to
"select MX6SX" to boards using i.MX6 SoloX.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Initial version for mx6sx SABREAUTO board support with features:
PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander.
