path: root/configs/mx6sxsabreauto_defconfig
2018-09-10MLK-19505: configs: add fastboot support for qspi u-bootHan Xu
add fastboot for qspi u-boot Signed-off-by: Han Xu <han.xu@nxp.com>
2018-07-08MLK-18787 mx6sxsabreauto: Fix vga stdout and stderrYe Li
The u-boot changed to check CONFIG_IS_ENABLED for SYS_CONSOLE_IS_IN_ENV, so we have to set the configuration in defconfig not in header file, otherwise the checking will fail and lead to use vga for stdout and stderr when video is enabled. Fix the issue by moving CONFIG_VIDEO and CONFIG_SYS_CONSOLE_IS_IN_ENV to defconfig and remove duplicated configurations from header file. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-04-27MLK-18152-6 configs: mx6sxsabreauto: Update and add build configsYe Li
Update mx6sxsabreauto defconfig to align with v2017.03. Add other configs to support QSPI1 boot, NAND boot and plugin. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-27imx: mx6sxsabreauto: enable more dm driversPeng Fan
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers for mx6sxsabreauto board. Drop non-DM code. Note: The i.MX DM drivers has such dependency. MXC GPIO -> MXC I2C -> PFUZE/REGULATOR MXC GPIO -> PCA953X MXC GPIO -> FSL_USDHC So the drivers needs to be enabled all to avoid compiling error. The uboot dm tree log: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver thermal [ ] |-- imx_thermal simple_bus [ + ] |-- soc simple_bus [ + ] | |-- aips-bus@02000000 simple_bus [ ] | | |-- spba-bus@02000000 gpio [ + ] | | |-- gpio@0209c000 gpio [ + ] | | |-- gpio@020a0000 gpio [ + ] | | |-- gpio@020a4000 gpio [ + ] | | |-- gpio@020a8000 gpio [ + ] | | |-- gpio@020ac000 gpio [ + ] | | |-- gpio@020b0000 gpio [ + ] | | |-- gpio@020b4000 simple_bus [ ] | | |-- anatop@020c8000 simple_bus [ ] | | |-- snvs@020cc000 pinctrl [ + ] | | `-- iomuxc@020e0000 pinconfig [ + ] | | `-- imx6x-sabreauto pinconfig [ + ] | | |-- i2c2grp-1 pinconfig [ + ] | | |-- i2c3grp-2 pinconfig [ ] | | |-- uart1grp pinconfig [ + ] | | |-- usdhc3grp pinconfig [ ] | | |-- usdhc3grp-100mhz pinconfig [ ] | | |-- usdhc3grp-200mhz pinconfig [ + ] | | |-- usdhc4grp pinconfig [ + ] | | `-- vccsd3grp simple_bus [ + ] | |-- aips-bus@02100000 mmc [ + ] | | |-- usdhc@02198000 mmc [ + ] | | |-- usdhc@0219c000 i2c [ + ] | | |-- i2c@021a4000 i2c_generic [ + ] | | | |-- generic_8 i2c_generic [ + ] | | | `-- generic_4e i2c [ + ] | | `-- i2c@021a8000 gpio [ + ] | | |-- gpio@30 gpio [ + ] | | `-- gpio@32 simple_bus [ ] | `-- aips-bus@02200000 simple_bus [ ] | `-- spba-bus@02200000 simple_bus [ + ] `-- regulators regulator [ + ] `-- regulator@0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27imx: mx6sxsabreauto: enable pinctrl driverPeng Fan
Enable pinctrl driver for mx6sxsabreauto board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27imx: mx6sx: add dts for mx6sxsabreauto boardPeng Fan
Add dts for mx6sxsabreauto board. dts related files imported fro Linux (commit e5517c2a5a4). Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-09-22configs: fsl: Move SPI/SPI-FLASH configs to defconfigJagan Teki
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs into respective used defconfigs. - CONFIG_FSL_QSPI - CONFIG_SPI_FLASH - CONFIG_SPI_FLASH_BAR - CONFIG_SPI_FLASH_STMICRO Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-03-26imx: mx6sx: move MX6SX to Kconfig entryPeng Fan
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to "select MX6SX" to boards using i.MX6 SoloX. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
