path: root/configs/mx6sxsabreauto_defconfig
2016-03-26imx: mx6sx: move MX6SX to Kconfig entryPeng Fan
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to "select MX6SX" to boards using i.MX6 SoloX. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
