path: root/configs/mx6sxsabreauto_defconfig
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-04Merge branch 'master' of git://git.denx.de/u-boot-imxTom Rini
2018-09-04imx: imx6sx-sabreauto: convert to use DM QSPI driverYe Li
To support DM QSPI driver: - Add -u-boot.dtsi to modify n25q256a@0 and n25q256a@1 compatible string to "spi-flash" and add "num-cs" property. - Enable DM SPI and DM SPI FLASH configurations - Remove iomux settings of qspi1 in board codes which is not needed for DM driver. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-27imx: mx6sxsabreauto: enable more dm driversPeng Fan
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers for mx6sxsabreauto board. Drop non-DM code. Note: The i.MX DM drivers has such dependency. MXC GPIO -> MXC I2C -> PFUZE/REGULATOR MXC GPIO -> PCA953X MXC GPIO -> FSL_USDHC So the drivers needs to be enabled all to avoid compiling error. The uboot dm tree log: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver thermal [ ] |-- imx_thermal simple_bus [ + ] |-- soc simple_bus [ + ] | |-- aips-bus@02000000 simple_bus [ ] | | |-- spba-bus@02000000 gpio [ + ] | | |-- gpio@0209c000 gpio [ + ] | | |-- gpio@020a0000 gpio [ + ] | | |-- gpio@020a4000 gpio [ + ] | | |-- gpio@020a8000 gpio [ + ] | | |-- gpio@020ac000 gpio [ + ] | | |-- gpio@020b0000 gpio [ + ] | | |-- gpio@020b4000 simple_bus [ ] | | |-- anatop@020c8000 simple_bus [ ] | | |-- snvs@020cc000 pinctrl [ + ] | | `-- iomuxc@020e0000 pinconfig [ + ] | | `-- imx6x-sabreauto pinconfig [ + ] | | |-- i2c2grp-1 pinconfig [ + ] | | |-- i2c3grp-2 pinconfig [ ] | | |-- uart1grp pinconfig [ + ] | | |-- usdhc3grp pinconfig [ ] | | |-- usdhc3grp-100mhz pinconfig [ ] | | |-- usdhc3grp-200mhz pinconfig [ + ] | | |-- usdhc4grp pinconfig [ + ] | | `-- vccsd3grp simple_bus [ + ] | |-- aips-bus@02100000 mmc [ + ] | | |-- usdhc@02198000 mmc [ + ] | | |-- usdhc@0219c000 i2c [ + ] | | |-- i2c@021a4000 i2c_generic [ + ] | | | |-- generic_8 i2c_generic [ + ] | | | `-- generic_4e i2c [ + ] | | `-- i2c@021a8000 gpio [ + ] | | |-- gpio@30 gpio [ + ] | | `-- gpio@32 simple_bus [ ] | `-- aips-bus@02200000 simple_bus [ ] | `-- spba-bus@02200000 simple_bus [ + ] `-- regulators regulator [ + ] `-- regulator@0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27imx: mx6sxsabreauto: enable pinctrl driverPeng Fan
Enable pinctrl driver for mx6sxsabreauto board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27imx: mx6sx: add dts for mx6sxsabreauto boardPeng Fan
Add dts for mx6sxsabreauto board. dts related files imported fro Linux (commit e5517c2a5a4). Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-09-22configs: fsl: Move SPI/SPI-FLASH configs to defconfigJagan Teki
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs into respective used defconfigs. - CONFIG_FSL_QSPI - CONFIG_SPI_FLASH - CONFIG_SPI_FLASH_BAR - CONFIG_SPI_FLASH_STMICRO Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-03-26imx: mx6sx: move MX6SX to Kconfig entryPeng Fan
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to "select MX6SX" to boards using i.MX6 SoloX. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
