path: root/configs/mx6sllevk_plugin_defconfig
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-17imx: mx6sllevk: add usb supportPeng Fan
Add usb support for mx6sllevk board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-12-16imx: mx6sllevk: add plugin supportPeng Fan
Add plugin support for mx6sllevk board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
