path: root/configs/mx6sabresd_spl_defconfig
2017-05-31mx6sabresd: Rename target to mx6sabresd_defconfigFabio Estevam
As mx6sabresd only supports SPL target now, there is no need to keep the 'spl' in the name of the target, so simply rename it to mx6sabresd_defconfig. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-05-18mx6sabresd: Prepare for supporting MX6DLFabio Estevam
Currently only MX6Q/QP sabresd boards are supported in SPL. In order to also support MX6DL we need to convert to using IOMUX_PADS and SETUP_IOMUX_PADS macros. Other than that move the <asm/arch/mx6-ddr.h> header inclusion to the SPL code block in order to avoid build error. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-20mx6saberesd_spl: Correct falcon mode additionTom Rini
When falcon mode support was added, it was right around when SPL_OS_BOOT was migrated to Kconfig. So first we must move the enablement to the defconfig file. Next, it turned off EXT support rather than add the information to allow for falcon mode from EXT. Add this information so that the board compiles after 5d28b930f237. Fixes: d96796ca23b2 ("mx6sabresd: Add Falcon mode support") Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-04-18ARM: mx6: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-13dm: mx6: sabre: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-13imx6: add spl config for mx6sabresdJohn Tobias
add a build configuration file for mx6sabresd with spl support Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
