path: root/configs/mx6sabresd_defconfig
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08imx: mx6sabresd: fix usb start when DM enabledPeng Fan
Enable CONFIG_DM_REGULATOR_FIXED to let vbus regulator work. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08mx6sabresd: Reduce overall SPL sizeFabio Estevam
Currently the SPL binary is 67 kB, which leaves only 1 kB of free internal RAM space. The following options can be safely removed to save some precious SPL space: - CONFIG_SPL_FS_EXT4: u-boot-dtb.img is stored in raw sector via dd command (at offset 69 kB) - CONFIG_SPL_I2C_SUPPORT: I2C is not used during SPL - CONFIG_SPL_OS_BOOT: no need to make Falcon mode supported by default After this change the SPL binary size gets down to 51 kB. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-09-21imx: mx6sabresd: fix splash logo drawingAnatolij Gustschin
After mxc_ipuv3 DM_VIDEO conversion showing splash image doesn't work. Fix this. Also enable white on black console configuration as it used to be with cfb_console driver. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Fabio Estevam <festevam@gmail.com> Tested-by: Fabio Estevam <festevam@gmail.com>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-21configs: Resync with savedefconfigTom Rini
2019-06-11mx6sabresd: Select pinctrl driverFabio Estevam
With the conversion to DM we should select the pinctrl driver. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-06-11mx6sabresd: Remove CONFIG_SPL_DM to decrease the SPL sizeFabio Estevam
Currently the mx6qsabresd board does not boot: U-Boot SPL 2019.07-rc2 (May 16 2019 - 14:28:55 -0300) Trying to boot from MMC1 spl: could not find mmc device 0. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### The reason for the boot failure is that that the SPL size got greater than the 68KB limit (4KB header + 64KB max size) as explained in include/configs/imx6_spl.h. Remove the CONFIG_SPL_DM option, so that the SPL binary could fit into the allowed size and the board can boot again. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-05-20imx: mx6sabresd: fix boot hang with videoPeng Fan
Meet the following boot hang. " U-Boot SPL 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800) Trying to boot from MMC1 U-Boot 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800) CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C)Reset cause: POR Model: Freescale i.MX6 Quad SABRE Smart Device Board Board: MX6-SabreSD I2C: ready DRAM: 1 GiB Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Some drivers failed to bind Error binding driver 'generic_simple_bus': -28 Some drivers failed to bind initcall sequence 4ffe4500 failed at call 1780dfb7 (err=-28) " 1. fdtdec_get_alias_seq will use "video" as base, however in alias node, we use ipux, so add new alias for U-Boot dts. 2. DM_VIDEO is enabled, however reserve_video is called before relocation, so to make DM_VIDEO work before relocation, need to set SYS_MALLOC_F_LEN 3. defconfig is updated with savedefconfig Note: I do not have a video panel to test, but with this patch, U-Boot boots up again, below log. " U-Boot SPL 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800) Trying to boot from MMC1 U-Boot 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800) CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C) at 34C Reset cause: POR Model: Freescale i.MX6 Quad SABRE Smart Device Board Board: MX6-SabreSD I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 3 Loading Environment from MMC... *** Warning - bad CRC, using default environment PCI: pcie phy link never came up In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 " Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-04-13mx6sabresd: convert to DM_VIDEOAnatolij Gustschin
Enable DM_VIDEO in defconfig. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-04-13imx: move CONFIG_VIDEO_IPUV3 to defconfigsAnatolij Gustschin
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-15configs: mx6sabresd: Reduce SPL size by disabling DOS, EXT and EFI supportAbel Vesa
With DM and FIT enabled in SPL, there is an sram overflow. By disabling CONFIG_SPL_DOS_PARTITION, CONFIG_SPL_EXT_SUPPORT and CONFIG_SPL_EFI_PARTITION, we get to keep the 'one binary to fit all' for imx6[q|qp|dl] on sabresd since the final SPL image is now under 64KB. Signed-off-by: Abel Vesa <abel.vesa@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-02-15configs: mx6sabresd: Add DM_SPI_FLASH necessary configsAbel Vesa
Enable all neceassary configs to support DM_SPI_FLASH on mx6sabresd. Signed-off-by: Abel Vesa <abel.vesa@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-02-15mx6sabresd: Add DM_GPIO supportAbel Vesa
Add the DM_GPIO related config for mx6sabresd. Also add the gpio request calls. Signed-off-by: Abel Vesa <abel.vesa@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-02-15configs: mx6sabresd: Add SPL FIT and DM supportAbel Vesa
Enable all the necessary configs for SPL DM and FIT support for mx6sabresd. Signed-off-by: Abel Vesa <abel.vesa@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2019-01-10Kconfig: rename CONFIG_SPL_USB_GADGET_SUPPORT as CONFIG_SPL_USB_GADGETJean-Jacques Hiblot
The SPL option for USB gadget should be named after the option for u-boot (CONFIG_USB_GADGET) Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-02-25Merge git://git.denx.de/u-boot-imxTom Rini
2018-02-18mx6sabresd: Select the CONFIG_EFI_PARTITION optionFabio Estevam
With fastboot support enabled, it is useful to be able to list the eMMC EFI partitions, so select the CONFIG_EFI_PARTITION option. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-10configs: Resync with savedefconfigTom Rini
2018-02-04mx6sabresd: Add fastboot supportFabio Estevam
fastboot tool is a convenient way to flash the eMMC, so add support for it. Examples of usages: On the mx6sabresd: => fastboot 0 On the Linux PC connected via USB: $ sudo fastboot getvar bootloader-version -i 0x0525 bootloader-version: U-Boot 2018.01-00550-g7517cfe finished. total time: 0.000s $ sudo fastboot reboot -i 0x0525 (this causes the mx6sabresd to reboot) Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Shawn Guo <shawn.guo@linaro.org>
2018-02-04mx6sabresd: Select CONFIG_CMD_USB_MASS_STORAGEFabio Estevam
Select CONFIG_CMD_USB_MASS_STORAGE so that the 'ums' can be used. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-11-20mx6: Select MX6QDL option via KconfigFabio Estevam
Currently the MX6QDL option is selected via CONFIG_SYS_EXTRA_OPTIONS, but it is better to select it directly via Kconfig. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-20mx6sabresd: Add Serial Download Protocol supportFabio Estevam
Add Serial Download Protocol support (SDP), which allows loading SPL and u-boot.img via imx_usb_loader tool as explained in doc/README.sdp. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
