path: root/configs/mx6qarm2_defconfig
2014-09-30imx: mx6dlarm2: Add support for i.MX6Q/DL arm2 LPDDR2 boardsYe.Li
Update the ddr scripts for LPDDR2 and add two build configs for LPDDR2 arm2 board. Since the LPDDR2 arm2 board has different DDR size, use CONFIG_DDR_MB in defconfig to replace the PHYS_SDRAM_SIZE. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-30imx: mx6dlarm2: Add support for i.MX6DL arm2 DDR3 boardYe.Li
This patch adds the i.MX6DL arm2 board support. The i.MX6DL ARM2 shared the same board with i.MX6Q ARM2 board since the i.MX6DL is pin-pin compatible with i.MX6Q. The patch also support the DDR 32-BIT mode option. Please define CONFIG_DDR_32BIT in the board configure file to enable DDR 32-BIT mode.But due to the board design, it's 64bit DDR buswidth physically, so, if you CONFIG_DDR_32BIT, the DDR memory size will be half of it. Signed-off-by: Ye.Li <B37916@freescale.com>
