Remove CONFIG_BCB_SUPPORT config from BSP u-boot defconfig files.
So that we can eliminate such errors during boot up:
can't find partition: misc, dump the partition table
idx 0, ptn 0 name='gpt' start=0 len=2048
idx 1, ptn 0 name='tos' start=0 len=2047
idx 2, ptn 0 name='all' start=0 len=7864320
idx 3, ptn 0 name='bootloader' start=2 len=4094
idx 4, ptn 1 name='mmcsdb1' start=20480 len=1024000
idx 5, ptn 2 name='mmcsdb2' start=1228800 len=6635520
cannot get the partion info for misc
Cannot find partition 4080
do_raw_read failed, ret 1
read_bootctl, bcb_rw_block read failed
read command failed
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 4d282a7a429876f1c1c67754a1d5c7aaaf75bb43)
i.MX6DL boards enable fastboot as default, support both sabresd and
sabreauto.
uuu will use fastboot command to write emmc.
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
In u-boot 2018, CONFIG_G_DNL_MANUFACTURER, CONFIG_G_DNL_VENDOR_NUM and
CONFIG_G_DNL_PRODUCT_NUM are changed to:
CONFIG_USB_GADGET_MANUFACTURER
CONFIG_USB_GADGET_VENDOR_NUM
CONFIG_USB_GADGET_PRODUCT_NUM
Fix them in imx6q/dl/qp/solo defconfigs, otherwise they are using default
value.
Add defconfigs to support various boot devices and platforms
for MX6DQ/DQP/DL/S sabreauto and sabresd boards.
