Remove CONFIG_BCB_SUPPORT config from BSP u-boot defconfig files.
So that we can eliminate such errors during boot up:
can't find partition: misc, dump the partition table
idx 0, ptn 0 name='gpt' start=0 len=2048
idx 1, ptn 0 name='tos' start=0 len=2047
idx 2, ptn 0 name='all' start=0 len=7864320
idx 3, ptn 0 name='bootloader' start=2 len=4094
idx 4, ptn 1 name='mmcsdb1' start=20480 len=1024000
idx 5, ptn 2 name='mmcsdb2' start=1228800 len=6635520
cannot get the partion info for misc
Cannot find partition 4080
do_raw_read failed, ret 1
read_bootctl, bcb_rw_block read failed
read command failed
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 4d282a7a429876f1c1c67754a1d5c7aaaf75bb43)
i.MX6DL boards enable fastboot as default, support both sabresd and
sabreauto.
uuu will use fastboot command to write emmc.
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
In u-boot 2018, CONFIG_G_DNL_MANUFACTURER, CONFIG_G_DNL_VENDOR_NUM and
CONFIG_G_DNL_PRODUCT_NUM are changed to:
CONFIG_USB_GADGET_MANUFACTURER
CONFIG_USB_GADGET_VENDOR_NUM
CONFIG_USB_GADGET_PRODUCT_NUM
Fix them in imx6q/dl/qp/solo defconfigs, otherwise they are using default
value.
Add defconfigs to support various boot devices and platforms
for MX6DQ/DQP/DL/S sabreauto and sabresd boards.
Now that mx6sabresd_spl_defconfig can be used to boot all
mx6sabresd variants, the non-SPL targets can be safely removed.
Signed-off-by: Fabio Estevam <fabio.estvam@nxp.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig.
Add enable "CONFIG_ARCH_MX6" for boards based on mx6.
Then we can choose target boards using "make ARCH=arm menuconfig"
with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when
"make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig,
kconfig will complains "arch/../configs/platinum_titanium_defconfig:3:
warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Eric BĂ©nard <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Soeren Moch <smoch@web.de>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Soeren Moch <smoch@web.de>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Before add CONFIG_SYS_MALLOC_F and CONFIG_SYS_MALLOC_F_LEN,
uboot will complains "CPU: Temperature: Can't find sensor device".
This is because DM and DM_THERMAL are enabled, but SYS_MALLOC_F
is not configured.
After applying this patch, uboot can correctly detect the temperature.
U-Boot 2015.04-rc2-00146-g48b6e30-dirty (Mar 09 2015 - 13:04:36)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
CPU: Temperature 44 C
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
Currently mx6dlsabresd shares the same DCD settings with the nitrogen board.
Provide a DCD configuration file specific to mx6dlsabresd with the settings
recommended by the Freescale hardware team.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
