path: root/configs/mx6dlsabreauto_defconfig
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-04-18ARM: mx6: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-02-13dm: mx6: sabre: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
