path: root/configs/mx53ppd_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25Convert CONFIG_USB_EHCI_MX5 to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_USB_EHCI_MX5 Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13imx: move CONFIG_VIDEO_IPUV3 to defconfigsAnatolij Gustschin
2019-04-13board: ge: store version information in fdtIan Ray
Add board-specific FDT function to store U-Boot version in device tree. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: ppd: Enable CONFIG_DM_MMCIan Ray
Use MMC device model, and remove USDHC pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: ppd: Enable CONFIG_DMIan Ray
Add simplified, generalised, ppd device tree and enable CONFIG_DM. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-17board: ge: Move VPD EEPROM configuration to the defconfigDenis Zalevskiy
Use standard configuration logic to define EEPROM constants. Names are based on VPD_EEPROM_ prefix because EEPROM_ is already used by i2c_eeprom driver. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-08-17Migrate bootlimit to KconfigAlex Kiernan
Migrate boards which set bootlimit in the environment to Kconfig. We exclude gurnard_defconfig which includes a bootlimit=, but doesn't set CONFIG_BOOTCOUNT_LIMIT, so we'd fail to include a bootlimit setting if we migrated it. display5_defconfig and display5_factory_defconfig share a SYS_CONFIG_NAME, but only display5_defconfig enables CONFIG_BOOTCOUNT_LIMIT, so we fail to set bootlimit= in display5_factory_defconfig. This is okay because the display5_factory_defconfig doesn't need to have it set, as it is only meant to prepare the board in the factory. Environment changes for all modified configs as seen from buildman: boards.cfg is up to date. Nothing to do. Summary of 3 commits for 32 boards (8 threads, 1 job per thread) 01: Merge git://git.denx.de/u-boot-x86 arm: + draco etamin rastaban pxm2 display5 thuban rut 02: Add BOOTCOUNT_BOOTLIMIT to set reboot limit 03: Migrate bootlimit to Kconfig - display5_factory: bootlimit=3 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-05-17ge: ppd: move CONFIG_ENV_IS_IN_MMC to defconfigSebastian Reichel
CONFIG_ENV_IS_IN_MMC must be declared in defconfig to properly support "env save". Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-24Merge CONFIG_BOOTCOUNT and CONFIG_BOOTCOUNT_LIMITAlex Kiernan
CONFIG_BOOTCOUNT was only used in mx53ppd, merge it with CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Ian Ray <ian.ray@ge.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-20mx53: Add Board support for GE PPDPeter Senna Tschudin
Create board support for GE PPD, based on mx53loco. Use mx53ppd_defconfig make target to configure for this board. Signed-off-by: Peter Senna Tschudin <peter.senna@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
