path: root/configs/mx53loco_defconfig
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30arm: Re-sync ARCH_MX5 / MX51 / MX53 CONFIG optionsTom Rini
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 / CONFIG_MX53 being in Kconfig. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
