path: root/configs/mx53cx9020_defconfig
2017-10-30configs: Resync with savedefconfigTom Rini
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-12imx: cx9020: try pxe boot, if no vmlinuz on mmcPatrick Bruenn
If no vmlinuz is found on mmc, try to boot from pxe. Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-16arm: imx: add i.MX53 Beckhoff CX9020 Embedded PCPatrick Bruenn
Add CX9020 board based on mx53loco. Add simplified imx53 base device tree from kernel v4.8-rc8, to reuse serial_mxc with DTE and prepare for device tree migration of other functions and imx53 devices. The CX9020 differs from i.MX53 Quick Start Board by: - use uart2 instead of uart1 - DVI-D connector instead of VGA - no audio - CCAT FPGA connected to emi - enable rtc Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
