path: root/configs/mx51evk_defconfig
2022-06-06Convert CONFIG_SYS_CBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_CBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_PBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_PBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08configs: Resync with savedefconfigTom Rini
2022-04-08Convert CONFIG_BOARD_SIZE_LIMIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_SIZE_LIMIT To do this, introduce CONFIG_HAS_BOARD_SIZE_LIMIT. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-18Convert CONFIG_ETHPRIME to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ETHPRIME This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME similar to other options that are not always set and control environment variables. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-18Convert CONFIG_ARP_TIMEOUT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ARP_TIMEOUT Cc: Ramon Fried <rfried.dev@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-01Convert CONFIG_USE_BOOTCOMMAND et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_USE_BOOTCOMMAND CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND CONFIG_NFSBOOTCOMMAND Signed-off-by: Tom Rini <trini@konsulko.com>
2021-11-01configs: Resync with savedefconfigTom Rini
2021-09-04i2c: Convert CONFIG_POWER_I2C et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_POWER_I2C CONFIG_POWER_LEGACY They are handled at the same time due to a dependency between them. Update the Makefile rule to use legacy power only in U-Boot proper. Unfortunately a separate rule is needed in SPL to be able to build legacy power. Add SPL related symbols for both, to allow for SPL-only usage. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> [trini: More SPL related cleanups, reword commit message] Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31Convert CONFIG_SYS_MALLOC_LEN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MALLOC_LEN Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-08-31imx: Finish migration of IMX_CONFIG to KconfigTom Rini
- Provide a default Kconfig value of the default script - Largely continue to define this via the board Kconfig file - For the boards that select a script based on defconfig rather than TARGET, keep this within the defconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31Convert CONFIG_SYS_LOAD_ADDR to KconfigTom Rini
Now that we have consistent usage, migrate this symbol to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-07-26configs: Resync with savedefconfigTom Rini
2021-06-28configs: Resync with savedefconfigTom Rini
2021-05-11configs: Resync with savedefconfigTom Rini
2021-03-01mx51evk: Convert to driver modelFabio Estevam
Make the conversion to driver model as it is mandatory. Tested booting the Linux kernel from the SD card. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-10-29configs: Resync with savedefconfigTom Rini
2020-10-18configs: migrate CONFIG_VIDEO_BMP_RLE8 to defconfigsPatrick Delaunay
Done with: ./tools/moveconfig.py VIDEO_BMP_RLE8 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-23Convert CONFIG_SPLASH_SCREEN et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPLASH_SCREEN CONFIG_SPLASH_SCREEN_ALIGN CONFIG_SPLASHIMAGE_GUARD CONFIG_SPLASH_SOURCE Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-17Convert CONFIG_MXC_UART to KconfigTom Rini
This converts the following to Kconfig: CONFIG_MXC_UART Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Peng Fan <peng.fan@nxp.com>
2020-06-18imx: convert mx51evk board to DM_VIDEOAnatolij Gustschin
Migration to DM_VIDEO driver is long overdue. Update defconfig to enable usage of converted ipuv3 driver DM configuration. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2020-04-28configs: Resync with savedefconfigTom Rini
2019-12-27mx51evk: Fix U-Boot corruption after saving the environmentFabio Estevam
U-Boot binary has grown in such a way that it goes beyond the reserved area for the environment variables. Running "saveenv" followed by a "reset" causes U-Boot to hang because of this overlap. Fix this problem by increasing the CONFIG_ENV_OFFSET size. Also, in order to prevent this same problem to happen in the future, use CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time. CONFIG_BOARD_SIZE_LIMIT does not accept math expressions, so declare CONFIG_ENV_OFFSET with its direct value instead. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25Convert CONFIG_USB_EHCI_MX5 to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_USB_EHCI_MX5 Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13imx: move CONFIG_VIDEO_IPUV3 to defconfigsAnatolij Gustschin
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
