path: root/configs/mx35pdk_defconfig
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-08Convert CONFIG_MXC_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MXC_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
