path: root/configs/mx31pdk_defconfig
2018-05-17mx31pdk: Convert CONFIG_MX31 flag to use Kconfig.Magnus Lilja
Move CONFIG_MX31 from mx31pdk.h to mx31pdk_defconfig and introduce necessary Kconfig changes as well. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-08Convert CONFIG_MXC_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MXC_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
