path: root/configs/mx28evk_defconfig
2020-10-18configs: migrate CONFIG_VIDEO_BMP_RLE8 to defconfigsPatrick Delaunay
Done with: ./tools/moveconfig.py VIDEO_BMP_RLE8 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-10-18configs: migrate CONFIG_VIDEO_BMP_GZIP to defconfigsPatrick Delaunay
Done with: ./tools/moveconfig.py VIDEO_BMP_GZIP The 3 suspicious migration because CMD_BMP and SPLASH_SCREEN are not activated in these defconfigs: - trats_defconfig - s5pc210_universal_defconfig - trats2_defconfig Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-10-09configs: Resync with savedefconfigTom Rini
2020-08-23Convert CONFIG_SPLASH_SCREEN et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPLASH_SCREEN CONFIG_SPLASH_SCREEN_ALIGN CONFIG_SPLASHIMAGE_GUARD CONFIG_SPLASH_SOURCE Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-06configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure CMD_NAND is compiled when its options are selectedMiquel Raynal
In some files, options of CMD_NAND are selected but not the command itself. Fix this inconsistency. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-23kconfig: Convert CONFIG_MXS_GPIO to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_MXS_GPIO Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/571260789 Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Peng Fan <peng.fan@nxp.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-13configs: Disable now unbuildable SPI options for boardsTom Rini
Now that various SPI related options depend on CONFIG_DEPRECATED, in order for platforms to build out of the box they need to disable various other options. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Marek Vasut <marex@denx.de> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-03-25Convert CONFIG_DEFAULT_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_DEFAULT_SPI_BUS CONFIG_DEFAULT_SPI_MODE Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_MXS_SPI to KconfigTuomas Tynkkynen
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08arm: imx: mx28: Move MX28 selection to KconfigStefan Agner
The motivation for moving MX28 selection to Kconfig is to be able to better handle NAND MXS selection through Kconfig. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
