CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SPL_DRIVERS_MISC
CONFIG_SPL_ENV_SUPPORT
CONFIG_SPL_GPIO
CONFIG_SPL_I2C
CONFIG_SPL_LDSCRIPT
CONFIG_SPL_LIBCOMMON_SUPPORT
CONFIG_SPL_LIBGENERIC_SUPPORT
CONFIG_SPL_LOAD_FIT_ADDRESS
CONFIG_SPL_MMC
CONFIG_SPL_NAND_SUPPORT
CONFIG_SPL_NO_CPU_SUPPORT
CONFIG_SPL_OS_BOOT
CONFIG_SPL_POWER
CONFIG_SPL_STACK_R
CONFIG_SPL_STACK_R_ADDR
CONFIG_SPL_WATCHDOG
CONFIG_SPL_TEXT_BASE
Rename these options so that CONFIG_IS_ENABLED can be used with them.
- Provide a default Kconfig value of the default script
- Largely continue to define this via the board Kconfig file
- For the boards that select a script based on defconfig rather than
TARGET, keep this within the defconfig.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
The board was not converted to DM_VIDEO before deadline, so disable
video support for now.
Cc: Fabio Estevam <festevam@gmail.com>
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
Done with:
./tools/moveconfig.py VIDEO_BMP_GZIP
The 3 suspicious migration because CMD_BMP and SPLASH_SCREEN
are not activated in these defconfigs:
- trats_defconfig
- s5pc210_universal_defconfig
- trats2_defconfig
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
In some files, options of CMD_NAND are selected but not the command
itself. Fix this inconsistency.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_MXS_GPIO
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/571260789
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Peng Fan <peng.fan@nxp.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Now that various SPI related options depend on CONFIG_DEPRECATED, in
order for platforms to build out of the box they need to disable various
other options.
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_DEFAULT_SPI_BUS
CONFIG_DEFAULT_SPI_MODE
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This converts CONFIG_NAND_MXS to Kconfig.
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
In order to provide a consistent user experience for imx board users,
remove the custom CONFIG_BOOTDELAY values from defconfig files, so that
all boards can use the default two second delay.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
