path: root/configs/mx25pdk_defconfig
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-11-07mx25: Move MX25 selection to KconfigFabio Estevam
The motivation for moving MX25 selection to Kconfig is to be able to better handle MX25 specific errata, so that an errata option can be selected at SoC level instead of board level. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Sebastien Bourdelin <sebastien.bourdelin@savoirfairelinux.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2017-10-12mx25pdk: Use generic filesystem commandsOtavio Salvador
This rework the board to use the generic filesystem commands instead of forcing the use of FAT for the boot files. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
