path: root/configs/mvebu_mcbin-88f8040_defconfig
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-11-16arm: mvebu: configs: Enable DISTRO_DEFAULTS for MACCHIATObinHeinrich Schuchardt
Enable DISTRO_DEFAULTS for mvebu_db_armada8k_defconfig mvebu_mcbin-88f8040_defconfig Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31pinctrl: mvebu: Enable support for the Armada 37xx pinctrl driverStefan Roese
To enable support for the Armada 37xx pinctrl driver, we need to change the Kconfig symbol for the Armada 7k/8k pinctrl driver and its dependencies to distinguish between both platforms and drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Konstantin Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com>
2017-03-23arm64: mvebu: Add default configuraton for MACCHIATOBin boardKonstantin Porotchkin
Add default configuration for MACHHIATOBin community board based on Aramda-8040 SoC. Change-Id: Ic6b562065c0929ec338492452f765115c15a6188 Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
