path: root/configs/mvebu_db-88f7040_defconfig
2017-03-29arm64: mvebu: Enable CONFIG_PHY_MARVELL in Armada7k/8k-DB defconfigStefan Roese
The Marvell PHY support is needed espescially for the A7040-DB with the SGMII port (port 2). As without the marvell PHY driver configuration for SGMII, ethernet won't work. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefan Chulski <stefanc@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-29arm64: mvebu: armada-7k/8k: Enable MVPP2 ethernet driverStefan Roese
Since we've now integrated the A7k/8k support in the mvpp2 ethernet driver, lets enable the support for both Marvell developments boards. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2017-01-26Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-01-25Convert CONFIG_ARCH_EARLY_INIT_R to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-25arm64: mvebu: Enable SDHCI/MMC support for the db-88f7040/8040Stefan Roese
This patch enables the MMC support for the SDHCI controller on the Armada 7k db-88f7040 and the Armada 8k db-88f8040 board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com>
2016-12-12arm64: mvebu: Enable hush parser in A8K default configurationKonstantin Porotchkin
Enable hush parser in Armada-7040 and Armada-8040 DB default configurations. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-12arm64: mvebu: Enable PCIe support in Armada-7040 configurationKonstantin Porotchkin
Enable PCIe bus support in Armada-7040 DB default configuration Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-12arm64: mvebu: Enable pin control support in A8K default configKonstantin Porotchkin
Enable mvebu pin control support in the default configuration files for Armada-7040 and Armada-8040 development boards Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-12arm64: mvebu: Enable BUBT command support in A8K default configKonstantin Porotchkin
Enable mvebu "bubt" command support in the default configuration file for Armada-7040 and Armada-8040 development boards Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-05arm64: mvebu: Rename db-88f7040 files to armada-8kStefan Roese
This moves some of the Armada DB-88F7040 board specific files to a more generic name: armada-8k. This is in preparation for the Armada-8k support which will be added soon. And since both platforms share most devices, lets also share most source files to not duplicate the code here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-27arm64: mvebu: Add Armada 7K db-88f7040 development board supportStefan Roese
This patch adds basic support for the Marvell Armada 7K DB-88F7040 development board. Supported are the following interfaces: - UART - SPI (incl. SPI NOR) - I2C - USB - SATA / AHCI Support for other interfaces will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
