path: root/configs/mt7981_sd_rfb_defconfig
2023-02-08Revert "lmb: Default to not-LMB_USE_MAX_REGIONS"Tom Rini
As explained by Philippe Schenker, I was misinterpreting what happened in the case where we do not set LMB_USE_MAX_REGIONS and so had re-introduced the problem I was attempting to more widely resolve. This reverts commit 007ae5d108a37564905ea1588cb279f3a522cc3d. Reported-by: Philippe Schenker <philippe.schenker@toradex.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2023-02-06lmb: Default to not-LMB_USE_MAX_REGIONSTom Rini
The LMB code allows for picking a hard limit on the number of regions it can know of, or to dynamically allocate these regions. The reason for this choice is to allow for the compiler to perform a size optimization in the common case. This optimization however, is very small, ranging from 196 bytes to 15 bytes saved, or in some cases, being larger. Now that we also have more regions covered by LMB (in order to protect various parts of our self at run time), the default of 8 is also much easier to hit and leads to non-obvious error messages (which imply that an area is protected, not that we're out of areas to add to the list). Switch to the dynamic use as the default. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-12configs: set CONFIG_LMB_MAX_REGIONS=64 for all mt798[16] boardsDaniel Golle
With recently added wireless offloading features in Linux [1] the number of reserved memory regions with MediaTek SoCs supporting offloading wireless-to-Ethernet traffic grew beyond the default (8) which breaks booting Linux: ERROR: Failed to allocate 0xa6ac bytes below 0xc0000000. device tree - allocation error FDT creation failed! resetting ... Raise CONFIG_LMB_MAX_REGIONS to 64 like it is already done for other SoCs which require a larger number of reserved memory regions, eg. exynos78x0 based a3y17lte, a5y17lte and a7y17lte or dragonboard845c. [1]: https://lore.kernel.org/netdev/e3489a697b404bd47447190cd2e5adf090ae61c2.1667687249.git.lorenzo@kernel.org/ https://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next.git/commit/?id=eed4f1ddad8c5ad7596b229caec8bd7b477b81ee Signed-off-by: Daniel Golle <daniel@makrotopia.org>
2022-11-10Convert CONFIG_SYS_NONCACHED_MEMORY to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_NONCACHED_MEMORY To do this we introduce CONFIG_SYS_HAS_NONCACHED_MEMORY as a bool to gate if we are going to have noncached_... functions available and then continue to use CONFIG_SYS_NONCACHED_MEMORY to store the size of said cache. We make this new option depend on both the architectures which implement support and the drivers which make use of it. Cc: Tom Warren <twarren@nvidia.com> Cc: Mingming lee <mingming.lee@mediatek.com> Cc: "Ying-Chun Liu (PaulLiu)" <paul.liu@linaro.org> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-10-31Rename CONFIG_SYS_TEXT_BASE to CONFIG_TEXT_BASESimon Glass
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE and this makes it imposible to use CONFIG_VAL(). Rename it to resolve this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-10-21configs: Resync with savedefconfigTom Rini
2022-09-23board: mediatek: add MT7981 reference boardsWeijie Gao
This patch adds general board files based on MT7981 SoCs. MT7981 uses one mmc controller for booting from both SD and eMMC, and the pins of mmc controller are also shared with spi controller. So three configs are need for these boot types: 1. mt7981_rfb_defconfig - SPI-NOR and SPI-NAND 2. mt7981_emmc_rfb_defconfig - eMMC only 3. mt7981_sd_rfb_defconfig - SD only Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
