Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Since mt7620 is added into Kconfig, the CONFIG_SOC_MT7628=y which is
omitted by default must be added back, otherwise make xxx_defconfig for
these boards will be configured for mt7620 platform.
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
CONFIG_CONS_INDEX
Since SPL now uses malloc to allocate the buffer for the compressed
image before decompression to the destination address, we need to
configure a big enough malloc space in SPL. 256k seems to be big
enough even for the GARDENA board.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Weijie Gao <weijie.gao@mediatek.com>
This patch adds support for mt7628 reference board. SPL_DM and DT are not
enabled for SPL to save about 17KiB for u-boot-spl.bin.
