path: root/configs/mscc_ocelot_defconfig
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-04-12dm: spi: Read default speed and mode values from DTPatrick Delaunay
This patch update the behavior introduced by commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT") In case of DT boot, don't read default speed and mode for SPI from CONFIG_* but instead read from DT node. This will make sure that boards with multiple SPI/QSPI controllers can be probed at different bus frequencies and SPI modes. Remove also use in boards of the value speed=0 (no more supported) for ENV in SPI by using CONFIG_ENV_SPI_MAX_HZ=0. DT values will be always used when available (full DM support of SPI slave with available DT node) even if speed and mode are requested; for example in splash screen support (in splash_sf_read_raw) or in SPL boot (in spl_spi_load_image). The caller of spi_get_bus_and_cs() no more need to force speed=0. But the current behavior don't change if the SPI slave is not present (device with generic driver is created automatically) or if platdata is used (CONFIG_OF_PLATDATA). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-23configs: mscc_ocelot: add network supportGregory CLEMENT
Now that network support is added for the ocelot platform, let's add it in the default configuration. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2019-01-19configs: Resync with savedefconfigTom Rini
2019-01-16mips: ocelot: Enable use of serial gpio for LEDLars Povlsen
This enables the use of the MSCC serial GPIO driver to control the LEDs on the MSCC VCoreIII 'ocelot' pcb123 and pcb120. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2019-01-16mips: mscc: luton+ocelot: Remove board config options, do probingLars Povlsen
As we are moving to multi-dtb and board detection, remove static board config options, and introduce board probing instead. Luton: This add single-binary support for the two MSCC luton-based reference boards - pcb090 and pcb091. The SoC chip ID is used to determine the board type. Ocelot: This add single-binary support for the two MSCC ocelot-based reference boards - pcb120 and pcb123. The PHY ids on specific ports are used to determine the board type. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2018-12-19MSCC: add board support for the Ocelots based evaluation boardsGregory CLEMENT
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123 Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
