CONFIG_CONS_INDEX
CONFIG_BOARD_TYPES
CONFIG_BOARD_EARLY_INIT_F
CONFIG_BOARD_EARLY_INIT_R
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
MTD support must be enabled when using mtdparts. Indeed, functions
like get_mtd_info(), get_mtd_device() and put_mtd_device() are in
drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
MTD must be enabled when there is a SPI NOR flash using the
SPI_FLASH_MTD config entry.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
arch/arm/dts/armada-385-amc.dts
arch/arm/dts/armada-xp-theadorable.dts
arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi
Update default confing to use network driver for Jaguar2 SoCs.
Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
This patch update the behavior introduced by
commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT")
In case of DT boot, don't read default speed and mode for SPI from
CONFIG_* but instead read from DT node. This will make sure that boards
with multiple SPI/QSPI controllers can be probed at different
bus frequencies and SPI modes.
Remove also use in boards of the value speed=0 (no more supported)
for ENV in SPI by using CONFIG_ENV_SPI_MAX_HZ=0.
DT values will be always used when available (full DM support of
SPI slave with available DT node) even if speed and mode are requested;
for example in splash screen support (in splash_sf_read_raw)
or in SPL boot (in spl_spi_load_image).
The caller of spi_get_bus_and_cs() no more need to force speed=0.
But the current behavior don't change if the SPI slave is not
present (device with generic driver is created automatically)
or if platdata is used (CONFIG_OF_PLATDATA).
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
Enable debug uart for Jaguar2 SoC family.
Add board support and configuration for Jaguar2 SOC family.
The detection of the board type in this family is based on the phy ids.
