path: root/configs/mk802_defconfig
2015-01-22sunxi: Add mk802 board / defconfigHans de Goede
The mk802 is the "classic" Allwinner A10 based hdmi tv-stick, it features 512M or 1G RAM, 4G nand, a mini-hdmi female connector, USB-A receptacle, mini-usb receptacle (OTG) and USB-wifi. Somewhat unique the mk802 does not use the AXP209 pmic, it does not have a pmic at all. For more details see: http://linux-sunxi.org/Rikomagic_mk802 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
