path: root/configs/miqi-rk3288_defconfig
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Ɓukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPLPhilipp Tomsich
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used. This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:] [fixed inverted CONFIG_IS_ENABLED test for rk3288:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> include/configs/rock.h: undef
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-10rockchip: video: Kconfig: Add Kconfig for rockchip video drivereric.gao@rock-chips.com
1. add Kconfig for rockchip video driver, so that video port can be selected as needed. 2. move VIDEO_ROCKCHIP option to new Kconfig for concision. Signed-off-by: Eric Gao <eric.gao@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Drop indenting in Kconfig: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: Add support for MiQi rk3288 boardJernej Skrabec
MiQi is rk3288 based development board with 1 or 2 GB SDRAM, 16 GB eMMC, micro SD card interface, 4 USB 2.0 ports, HDMI, gigabit Ethernet and expansion ports. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
