path: root/configs/microblaze-generic_defconfig
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-08-02xilinx: Sync defconfigs with the latest Kconfig layoutMichal Simek
Update Microblaze, Zynq and ZynqMP defconfigs to reflect latest Kconfig changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Move MSR instruction selection to KconfigMichal Simek
Select MSR instructions via Kconfig instead of xparameters.h. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Select compilation flags via KconfigMichal Simek
Remove autogenerated config.mk and select CPU options via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable HUSH via KconfigMichal Simek
Cleanup board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move CONFIG_NETCONSOLE to KconfigMichal Simek
2016-01-27microblaze: Remove CONFIG_FIT from board fileMichal Simek
And enable it via defconfig by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move eth configuration to KconfigMichal Simek
Cleanup board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable axi emac via KconfigMichal Simek
Enable driver by default for all platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27microblaze: Enable PHYLIB via KconfigMichal Simek
Cleanup board configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable uart16550 DM by defaultMichal Simek
Microblaze is uses uartlite or uart16550 as console drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27serial: uartlite: Move driver to DMMichal Simek
Enable SPL DM too. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-20microblaze: move CONFIG_SYS_TEXT_BASE to defconfigMasahiro Yamada
This is how CONFIG options are defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Enable DM by defaultMichal Simek
Enable DM for the whole architecture. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Enable OF_CONTROL by defaultMichal Simek
2015-12-18microblaze: Use malloc setting via KconfigMichal Simek
Clean board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
