Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Enable this feature by default to be able to work with env import/export
commands which are done in this slightly changed variable format (There is
addtional flag fields in variable file which is changing CRC calculation).
Remove fixed configuration and detect flash based on DT.
Also increase amount of flash sectors to 2048 because on kc705 flash has
1027 sectors.
Bank # 1: CFI conformant flash (16 x 16) Size: 128 MB in 1027 Sectors
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x8962
Erase timeout: 4096 ms, write timeout: 2 ms
Buffer write timeout: 5 ms, buffer size: 1024 bytes
In board_late_init() several variables are setup to match the current
configuration.
Microblaze has been converted fully to DM that's why enabled DM for I2C
too.
Add distro boot support for microblaze and enable jtag, qspi,
dhcp, pxe boot targets for distro boot.
Enable DISTRO_DEFAULTS config in microblaze defconfig and also
enable support for spi xilinx driver & spi vendors to access
spi flash by distro boot.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
In case that mac address is not found it is generated randomly.
The whole cache code needs to be redesign to read information about cache
from DT instead of macro selection. Enable caches by default because
systems have caches on by default for Linux.
Also enable CMD_CACHE to be able to disable cache if there is any issue.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Show information about board read from DT by default to know what board
U-Boot is running at.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
There are some inconsistencies which should be fixed.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
Enable led support for boards which have "gpio-leds" node.
And also for microblaze which is converted to DM_GPIO now.
Tested on zcu100.
Converting GPIO to DM requires to do changes in reset subsystem
that's why support for Microblaze soft reset via sysreset and GPIO
sysreset support was added.
These two patches enables enabling GPIO DM.
Microblaze soft reset is bind at last reset method.
GPIO reset is handled via sysreset with adding this fragment to DT.
gpio-restart {
compatible = "gpio-restart";
gpios = <&reset_gpio 0 0 0>;
/* 3rd cell ACTIVE_HIGH = 0, ACTIVE_LOW = 1 */
hard-reset-gpio property is not documented and also handled.
Conversion is required.
Unfortunately do_reset is required for SPL that's why use only soft
microblaze reset for now.
DM watchdog should be enabled by default.
This patch removes UBI support from defconfig and it can
be enabled from menuconfig as per need.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Make defconfigs up2date with current location.
This patch added Kconfig support for CONFIG_XILINX_GPIO
and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Xilinx changes for v2018.03
- Several Kconfig fixes (also moving configs to defconfigs)
- Some DTS updates
- ZynqMP psu rework based on Zynq concept
- Add low level initialization for zc770 and zcu102
- Add support for Zynq zc770 x16 nand configuration
- Add mini nand/emmc ZynqMP targets
- Some arasan nand changes
This patch moved ethernet PHY configs of Microblaze board to
Now that we have everything in place in the code, let's allow to build
multiple environments backend through Kconfig.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
At present we support multiple environment drivers but there is not way to
select between them at run time. Also settings related to the position and
size of the environment area are global (i.e. apply to all locations).
Until these limitations are removed we cannot really support more than one
environment location. Adjust the location to be a choice so that only one
can be selected. By default the environment is 'nowhere', meaning that the
environment exists only in memory and cannot be saved.
Also expand the help for the 'nowhere' option and move it to the top since
it is the default.
[trini: Move all of the imply logic to default X if Y so it works again]
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be
set.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_CMD_SAVES
CONFIG_CMD_MMC_SPI
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_JFFS2
