path: root/configs/medcom-wide_defconfig
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
