This is needed for the upcoming ethernet DM conversion of the maxbcm
board. The configuration of the PHY is then extracted from the DT
instead of using the defines from the config header.
Cc: Luka Perkov <luka.perkov@sartura.hr>
This patch adds full DM support to the SPL on MVEBU. Currently
only serial is supported. Other drivers will follow.
This patch also adds the necessary config values for the DEBUG UART
to the MVEBU defconfig files. This came in handy while implementing
this DM support.
Additionally, the mvebu specific SPL linker script is removed and
this common one is used instead:
arch/arm/cpu/u-boot-spl.lds
This common linker script already handles all special cases. No need
to reinvent the wheel for MVEBU here.
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
This patch adds driver model support for some Marvell MVEBU SoC's. Including
Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now
selected automatically for MVEBU platforms.
With this DM support now available for MVEBU, hardcoding the base addresses
and other information is not necessary any more. Probing should be done
by using the values provided via the device tree now instead. For this
the driver also need to be converted to DM. Patches for some of the drivers
will follow.
Introduce a mach-mvebu/Kconfig for all Armada based SoC's.
This commit moves:
- CONFIG_SPI_FLASH_BAR
from include/configs/*.h into configs/*_defconfigs
Signed-off-by: Jagan Teki <jteki@openedev.com>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
This patch adds SPL support to the maxbcm MV78460 based board. Including
the fixed DDR configuratrion needed for the DDR training code. And the
the serdes PHY init code.
Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
The maxBCM board is equipped with the Marvell Armada-XP MV78460 SoC. It
integrates an SPI NOR flash and an Marvell 88E6185 switch.
