path: root/configs/maxbcm_defconfig
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add armada-xp-maxbcm.dts for maxbcm boardStefan Roese
This is needed for the upcoming ethernet DM conversion of the maxbcm board. The configuration of the PHY is then extracted from the DT instead of using the defines from the config header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Add DM (driver model) supportStefan Roese
This patch adds driver model support for some Marvell MVEBU SoC's. Including Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now selected automatically for MVEBU platforms. With this DM support now available for MVEBU, hardcoding the base addresses and other information is not necessary any more. Probing should be done by using the values provided via the device tree now instead. For this the driver also need to be converted to DM. Patches for some of the drivers will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-20arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig fileStefan Roese
Introduce a mach-mvebu/Kconfig for all Armada based SoC's. Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-02-06arm: maxbcm: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the maxbcm MV78460 based board. Including the fixed DDR configuratrion needed for the DDR training code. And the the serdes PHY init code. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
