path: root/configs/malta_defconfig
2016-05-26malta: Use device model & tree for UARTPaul Burton
Make use of device model & device tree to probe the UART driver. This is the initial step in bringing Malta up to date with driver model, and allows for cleaner handling of the different I/O addresses for different system controllers by specifying the ISA bus address instead of a translated memory address. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
