path: root/configs/malta64el_defconfig
2019-01-16MIPS: malta: switch to CONFIG_OF_SEPARATEDaniel Schwierzeck
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-10-09Kconfig: Convert CONFIG_RTC_MC146818 to KconfigSimon Glass
Move this option to Kconfig and tidy up the two boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-31MIPS: malta: add defconfigs for MIPS64Daniel Schwierzeck
Add defconfigs for recently introduced MIPS64 support on Malta boards to get more build coverage for MIPS64. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
