path: root/configs/m28evk_defconfig
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
