CONFIG_FSL_QIXIS
CONFIG_QIXIS_I2C_ACCESS
CONFIG_DIMM_SLOTS_PER_CTLR
CONFIG_RESET_PHY_R
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
Move the SATA options inside an 'if SATA' part, so they are grouped.
Fix the 'Complient' typo while we are here.
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
In order to finish moving this symbol to Kconfig for all platforms, we
need to do a few more things. First, for all platforms that define this
to a function, introduce CONFIG_DYNAMIC_SYS_CLK_FREQ, similar to
CONFIG_DYNAMIC_DDR_CLK_FREQ and populate clock_legacy.h. This entails
also switching all users from CONFIG_SYS_CLK_FREQ to get_board_sys_clk()
and updating a few preprocessor tests.
With that done, all platforms that define a value here can be converted
to Kconfig, and a fall-back of zero is sufficiently safe to use (and
what is used today in cases where code may or may not have this
available). Make sure that code which calls this function includes
<clock_legacy.h> to get the prototype.
CONFIG_VID
CONFIG_VOL_MONITOR_INA220
CONFIG_VOL_MONITOR_IR36021_READ
CONFIG_VOL_MONITOR_IR36021_SET
CONFIG_VOL_MONITOR_LTC3882_READ
CONFIG_VOL_MONITOR_LTC3882_SET
To finish this migration, we first need to introduce CONFIG_SPL_VID as
some platforms only use this code in full U-Boot while others use it in
SPL as well. To make the Kconfig logic clearer, guard all of the
sub-options with a if VID || SPL_VID check. Finally, add Kconfig
options for the remaining related options that did not previously have
one.
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_PL011_SERIAL
CONFIG_PL01X_SERIAL
CONFIG_PHYLIB
CONFIG_PHY_ATHEROS
CONFIG_PHY_GIGE
CONFIG_MII
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
LX2160A-RDB/QDS has micron mt35xu512aba flash which requires flag
CONFIG_SPI_FLASH_MT35XU on to probe flash successfully.
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson <stcarlso@linux.microsoft.com>
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
There is no Spansion flash on LX2160A-RDB/QDS boards.
Unset CONFIG_SPI_FLASH_SPANSION option for both the boards.
Enable CMD_GPIO for board lx2160ardb
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Move CORTINA_NO_FW_UPLOAD to Kconfig file so that it can
be controlled via defconfig files.
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
LX2160A-Rev1 uses PCIe layerscape Gen4 controller.
Enable CONFIG_PCIE_LAYERSCAPE_GEN4 for lx2160a.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Enable support to compile OPTEE driver, access AVB TA
and RPMB API's access via RPC from OPTEE for lx2160
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_NVME and CONFIG_CMD_NVME for Layerscape
platforms
Enable eMMC HS400 mode support on LX2160ARDB.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Enable support to compile SBSA driver.
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Add Root Complex and Endpoint mode specific config entries, such that
it's feasible to enable the RC and/or EP mode driver indepently.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Enable CONFIG_DM_ETH and CONFIG_DM_MDIO and related configs for the
LX2160ARDB board.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
CONFIG_ENV_ADDR helps in picking environment from flash before DDR init.
Define the value as 0x20500000 for lx2160ardb and lx2160aqds.
Enable FSPI controller support. So, flash environment can now be used.
The eMMC HS200 speed mode on Layerscape platforms has not been
supported properly. The eSDHC clock tuning has not been implemented
by now. So disable it until it is supported properly in case of
any potential issues.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Enable GIC_V3_ITS config to program GIC LPI
configuration table.
